3~5日配送 送料無料(12,000円以上のご注文)
概要 レビュー
新商品
K-Edgeエアロレースマウント(ELEMNT BOLT用)
¥9,250
その他のビュー
新商品
SKU# WFCC3M3
¥9,250
  • 3~5日配送 送料無料(12,000円以上のご注文)
  • 30日間、簡単に返品できます
  • 1年間の限定保証
レビュー
商品概要
K-EDGEとの共同設計により、K-EDGEの強度とWahoo BOLTの空気力学に基づいた優れた形状を兼ね揃えた究極の製品が実現しました。UCIワールドツアーチーム、ボーラ・ハンスグローエ、カチューシャ・アルペシンによって使用され、その信頼性が実証されています。
  • 31.8mmのハンドルバー
  • 色:ブラック
  • CNC切削加工アルミニウム
  • 空力設計
  • UCI自転車重量規定に基づいてロック可能
  • 重量:35グラム
K-Edge Aero Race Mount for ELEMNT BOLT is rated 4.2 out of 5 by 5.
Rated 4 out of 5 by from Well made with one small flaw I have been awaiting this product for some time as my bars are semi aero and the standard mount doesn't quite sit correctly. This mount solved the original issue but I have found that after only a few uses the device rattles around on the mount! It sounds like a cable knocking against my frame and after going through each cable individually finally realised its the Element making all the noise. I'm not sure if it is the mount or my device that has the issue but annoying either way.
Date published: 2018-08-30
Rated 5 out of 5 by from Great product Looks good, and my Wahoo Elmnt Bolt is more strongly fixed than with the usual mount!
Date published: 2018-08-13
Rated 2 out of 5 by from Not as aero as you would expect for the price I bought this because the Wahoo mounts are perpetually out of stock. The cnc aluminum is nice, the clamp is first quality. There is a large square hole in the bottom of the mount, which the Wahoo mount does not have. I guess K-edge does not understand that one of the main marketing points of the Bolt is its aerodynamic design.
Date published: 2018-07-23
Rated 5 out of 5 by from Special Mount Special and beautiful race mount. The adjustment about handlebar is ideal,
Date published: 2018-07-16
Rated 5 out of 5 by from Solid addition to the Elemnt Bolt I bought this because I found the plastic aero mount that comes with the Bolt a little flimsy. It naturally weighs more than the plastic alternative, 35g compared to circa 20g. While the plastic mount appears to look more aero (this holds the Bolt a mm or two further away) this is absolutely solid - and keeps the computer vibration and movement free. The difference is noticeable when using turn-by-turn navigation, looking at the screen for short periods of time, as opposed to just glancing a look of your vital stats.
Date published: 2018-05-11
  • y_2018, m_12, d_12, h_19
  • bvseo_bulk, prod_bvrr, vn_bulk_2.0.9
  • cp_1, bvpage1
  • co_hasreviews, tv_0, tr_5
  • loc_en_US, sid_WFCC3M3, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 12.37ms
商品概要
  • 31.8mmのハンドルバー
  • 色:ブラック
  • CNC切削加工アルミニウム
  • 空力設計
  • 重量:35グラム
機能
仕様
カリフォルニア州にお住いのお客様:カリフォルニア州法プロポジション65の警告をご覧ください。
レビュー
警告:発がん性または生殖毒性 - www.P65Warnings.ca.gov
Powered By OneLink
