心拍数トレーニングは、サイクリストにとって重要なツールです。強く、速くそして健康を向上するのに役立ちます。一方で、過度のトレーニングと疲労を防ぎます。But that’s only if you know what to look for, how to find it, and how to track it. However, before you start tracking your heart rate, it’s important to understand what exactly goes into this type of training.
THE BASICS
Your heart rate is the number of times your heart beats per minute as it pumps blood through your system. It’s your body’s response to the work you’re doing, so the harder your ride, the higher your heart rate.
Two of the most important numbers in heart rate training are your resting heart rate (the number of beats per minute while resting) and your maximum heart rate (the highest number your heart contracts in one minute).
This figure serves as a baseline for your overall health and fitness levels: as your fitness increases, your resting heart rate decreases. Your body becomes more efficient and less effort is needed to pump blood through your system.
FINDING YOUR RESTING HEART RATE
The best way to determine your resting heart rate is to take it first thing in the morning, every day for a week. (Make sure to do this during a week when you’re not sick or experiencing stress.)
- If you have a heart rate monitor, simply put it on and lie down for a few minutes, staying as relaxed as possible. Note the lowest number you see and repeat the next day.
- If you don’t have an HR monitor, find your pulse – either on the inside of your wrist or on your neck – and count the number of beats you feel for one minute (or for 30 seconds and multiply by 2).
At the end of the week, average the seven numbers together and that’s your resting heart rate.
FINDING YOUR MAXIMUM HEART RATE
By knowing your max HR, you’ll be able to determine how hard (or easy) each of your workouts should be.
The method below is another option. All you need is your bike and a long, steady hill.
After a 15-minute warm-up, complete the following:
1. Start off at a quick pace, increasing your speed every minute.
2. For about five minutes, stay seated.
3. When you can’t go any faster while sitting, get out of the saddle and sprint as hard as you can for 15 seconds.
4. Immediately take your heart rate and you’ll have your max heart rate.
5. Curse yourself for not downloading the Wahoo Fitness App, which could have made it all easier.
While we’re on the topic of max HRs, it’s interesting to note the number can vary from sport to sport. For example, your running max HR is likely higher than your cycling max HR. That’s because max HR is dependent on the size of muscle groups used, and running uses the largest muscle groups in the body. As a result, it’s crucial you determine your max HR individually for all of your athletic activities.
HEART RATE TRAINING: THE ZONES
Now that you know your resting and max heart rates, you can use these numbers in your cycling training.
There are five different heart rate training zones. We’ll start with the lowest and work our way up.
ゾーン1
RECOVERY
Intensity: 50-60% of your max HR
Active recovery workouts help you recover from hard efforts by flushing out lactic acid from the body. These workouts help with fatigue and soreness – but only if you make sure to keep them easy. Otherwise, you won’t get the benefits, and instead, you’ll risk overtraining. This is also the heart rate you want for the “recovery” part of your cycling intervals.
ゾーン2
ENDURANCE TRAINING
Intensity: 60-70% of your max HR
This should be the foundation of your training and make up the bulk of your workouts – especially if you’re a beginner cyclist. It’s where you build your base and burn fat, and it’s an intensity you should be able to comfortably hold for an extended period of time – all while chatting and enjoying the scenery. Your long rides should be at this intensity. You’re working harder than active recovery; but not so hard that it’s uncomfortable.
ゾーン3
AEROBIC CAPACITY (TEMPO)
Intensity: 70-80% of your max HR
This type of training improves aerobic fitness, power, strength, and blood circulation, and it’s often mixed in with Zone 2 training. The best way to describe it is “comfortably hard”. You’re working, and you feel it. But you can keep pushing through.
ゾーン4
LACTATE THRESHOLD
Intensity: 80-90% of your max HR
Also known as the anaerobic threshold, this type of training increases maximum performance capacity enhances lung capacity, and improves high-speed endurance. That said, this type of training is very challenging – it’s not an effort that can be sustained for long – so it’s best used in interval training with periods of active recovery.
ゾーン5
VO2
Intensity: 90-100% max HR
This is one of the most intense types of training, and it’s an effort you can sustain for maybe 3 to 8 minutes at a time. Your legs will burn as you push your bike forward, and you’ll be gasping for air. While very intense, this type of ride helps train your heart to quickly bring blood where it’s needed in your body, making you a more efficient rider and racer.
TRACKING YOUR HEART RATE
While the old school way of taking two fingers to your wrist or neck does to determine your heart rate gets the job done, it can be difficult to derive an exact number in the midst of a workout – especially for cyclists. If you are cycling, removing one hand to feel for a pulse can be a little dangerous, to say the least. After all, you run the risk of cycling into a pedestrian, tree or car. None of those are very appealing options.
That’s where Wahoo’s heart rate monitors can help you track and adjust your effort so your heart rate falls within a specific zone in real-time. You don’t have to remove your focus from your workout. That makes tracking your heart rate easier and your workout more efficient.
In addition, pairing a heart rate monitor with our ELEMNT GPS bike computers allows you to easily view your heart rate – letting you adjust as needed and stay on target. The ELEMNT bike computers display all of the stats you need during your ride, including speed, distance, ride time, and a handy clock. You can also link both of these devices to various apps to help you analyze your cycling data.
By tracking your heart rate in your cycling workouts, you’ll become a more efficient rider and athlete. You’ll know when to push harder and when to cut back, and you’ll become better attuned with your body.
7 July 2016
Is there a way to view the zones after the ride is stored? I can view the zones on my RFLKT as I ride, but have never been able to view them after the ride is saved. It would be nice if that was added or available.
13 July 2016
I have the same question as Dan. Also exporting workouts to other apps like strava or ridewithgps doesn’t give you insight in the heart rithem zones. Whe riding same routes this data would be very welcome to analyse progress
27 July 2016
I still don’t get how this voodoo works but this chest strap accurately displays my cadence. It’s voodoo. It’s magic !!
29 July 2016
[…] since 2013, I begin my training about six to seven months out with progressively longer weeks of Zone 2 base training. I try to stack big weeks of say, 15 to 20 hours of riding on top of each other so […]
13 August 2016
Great advice! Any quick thoughts on a few exercises or programs that would be good for each of those zones? For example, 30 seconds of burpees would get you into which zone? Or 15 seconds 100% sprint a spin bike?
2 September 2016
Carmichael Training Systems has some great plans for training with HR as well as Training Peaks.
2 March 2017
I think the 15minutes might be a typo.
3 March 2017
you are correct. We have changed it. Thanks
11 April 2017
On the Wahoo Elemnt Bolt, the HR zone display is one number. Is it possible, or is there a plan to display it with a decimal point or big number small number to know where within each zone you are or how close you are to the next zone ie. 3.2 – low zone 3; 3.7 high zone; 3.9 border line zone 4?
26 April 2017
not currently but worth considering. Thanks!
31 August 2018
This is the perfect site for everyone who wishes to find out about this topic. You understand a whole lot its almost hard to argue with you (not that I personally would want to…HaHa). You definitely put a fresh spin on a subject which has been written about for ages. Great stuff, just wonderful!
21 September 2021
I must be missing something. All of the zones are based on a percentage of max heart rate. So what is the point of measuring resting heart rate?
